Scratchbuilders!: Armor/AFV
This is a group for armor scratchbuilding questions, topics and projects.
Hosted by Mike Kirchoff
UR 416
megahobby
KitMaker: 46 posts
Posted: Thursday, June 29, 2017 - 12:02 AM UTC
Well, I took some time and was finally able to make the tire with the right detail and now I am very satisfied with the result. At the moment I will update the photos that have been deleted and I will continue with the project to finish it in the medium term and if everything goes well until I can take a template to reproduce it for sale jejeje
megahobby
KitMaker: 46 posts
Posted: Monday, February 11, 2013 - 08:51 AM UTC
casi listo para el acabado final, solo me falta corregir unos detallitos y quitar unos rayones
megahobby
KitMaker: 46 posts
Posted: Saturday, July 28, 2012 - 07:20 AM UTC
BUeno, continuando con este modelito... ya pude realizar una buena pieza para luego realizar el grabado, esta es la pieza con la proteccion de las partes que quiero realizar.
y luego del proceso de grabado, este fue el resultado, para el proximo fotograbado ya se que tengo que hacer las lineas de sujecion mas anchas, para que no se me caigan las pecitas como me paso en esta oportunidad
megahobby
KitMaker: 46 posts
Posted: Saturday, November 26, 2011 - 03:21 AM UTC
After several attempts to achieve closer to the shape of the hinges of the roof hatches as well as the base of the rail where the machine gun is, being as follows
megahobby
KitMaker: 46 posts
Posted: Saturday, November 26, 2011 - 03:17 AM UTC
Finally, cutting the chassis is about 7 mm so that the square wheel.
megahobby
KitMaker: 46 posts
Posted: Saturday, November 26, 2011 - 03:15 AM UTC
also made ​​some adjustments to the body for lateral alignment and correct placement of the front and rear
megahobby
KitMaker: 46 posts
Posted: Saturday, November 26, 2011 - 03:12 AM UTC
Well, I have set the pattern for the blocks of the tires ... hard work starts now
megahobby
KitMaker: 46 posts
Posted: Sunday, August 14, 2011 - 05:41 AM UTC
As the footprint of tire UR 416 is not equal to bringing revell model, I searched for this type of tire for most of the houses of modeling on the Internet (Dunlop 13) but was in vain and that is why I had no choice to design the footprint of the tire and then make a homemade vulcanization ... until now I have a good distribution of the blocks very similar to the original footprint
megahobby
KitMaker: 46 posts
Posted: Saturday, August 06, 2011 - 05:10 AM UTC
Well now I'm putting overalls and tanks of gasoline drawers. I notice that I have to make a cut to the chassis to fit in with the body of the UR 416. Here's the comparison.
Bueno ahora estoy colocando los guardapolvos y los cajones de tanques de gasolina. Observo que tengo que hacerle un recorte al chasis para que cuadre con la carrocería del UR 416. Acá esta la comparación.
megahobby
KitMaker: 46 posts
Posted: Saturday, August 06, 2011 - 05:01 AM UTC
TESTING THE CHASSIS - PROBANDO EL CHASIS
megahobby
KitMaker: 46 posts
Posted: Saturday, August 06, 2011 - 04:52 AM UTC
Estoy indeciso en cual de estos dos modelos realizare al final, solo cambia el color.
I'm undecided on which of these two models will make at the end, just change the color.
megahobby
KitMaker: 46 posts
Posted: Thursday, August 04, 2011 - 01:17 PM UTC
Este es un prototipo el cual me ayudara a corregir ciertos detalles y observaciones que me hagan para luego hacer el molde. Esta es una conversion para ser colocada en el chasis de unimog (3082 de revel) con su respectiva modificacion del chasis.
megahobby
KitMaker: 46 posts
Posted: Thursday, August 04, 2011 - 01:16 PM UTC
megahobby
KitMaker: 46 posts
Posted: Thursday, August 04, 2011 - 01:13 PM UTC
Hello, I have little information about the history of this vehicle, if anyone knows anything about it I would appreciate a lot for placement of introduction.
Having contacted some fellow soldiers got access to the observation, taking photographs and measurements of this issue, then bring to the table design in AutoCAD managed to get a plan of this scale model 1 / 35 very close to reality . With a little patience and I CONSEG scrash together the pieces being as follows
Que tal, tengo poca informacion sobre la historia de este vehiculo, si alguno sabe algo al respecto mucho se lo agradeceria para colocarlo de introduccion.
Luego de haber contactado a algunos compañeros militares consegui acceso para la observacion, toma de fotos y medidas de este ejemplar, luego de llevarlo a la mesa de diseño en AutoCAD logrando conseguir un plano de este modelo a escala 1/35 muy cercano a la realidad. Con un poco de paciencia y scrash pude consegir unir las piezas quedando de la siguiente manera
