Science Fiction
Discuss any and all forms of sci-fi modeling here.
Official tread: Sci-Fi IV
Cbacon84
KitMaker: 204 posts
ModelGeek: 60 posts
Posted: Friday, July 13, 2018 - 08:02 PM UTC
Finished up the FG Zaku II F Type tonight, and am overall happy with it, though I think i rushed the sanding job on the left forearm a bit or might have been due to how i constructed it, kind of hard to sand with the whole body attached. Though still was some good learning experience and I think next time I will construct the arms entirely before attaching them rather then do it piecemeal like I did this time. Still a good inexpensive kits to practice or experiment on.
Now back to the HGUC Zaku and GM-79 I originally started for this campaign.
Here's the FG F Type next to the J type I built previously. Still think the J type has oversized feet.
Bluestab
South Carolina, United States
KitMaker: 2,157 posts
ModelGeek: 120 posts
Posted: Monday, July 16, 2018 - 05:36 PM UTC
Casey, thanks. I'm sort of looking for kits that could be used as 1/35-ish robots and power-armor. I liked the look of that one, but I think it'll be too big for what I want it for.
I've got another project set for 1/24 scale that something like that could work with.
Cbacon84
KitMaker: 204 posts
ModelGeek: 60 posts
Posted: Monday, July 16, 2018 - 06:48 PM UTC
your welcome. Might try some of the VOTOMS kits by wave or the older ones by bandai which are 1/35 scale,though they might still be big for what you want to do.
https://hlj.com/product/WAVBK-222
KitMaker: 1,208 posts
ModelGeek: 303 posts
Posted: Tuesday, July 17, 2018 - 10:00 PM UTC
well i have managed to sneak a bit of work in on this kit. I have coated the window with clear floor polish and left them to dry for twenty four hours before installing them. as you can see in this picture the last window section has been installed and held in place using a clothes peg.
i have also used more of that marvellous stuff, Perfect Putty to fill gap where the upper turret meets the upper hull.
Pave-Hawk
Western Australia, Australia
KitMaker: 890 posts
ModelGeek: 70 posts
Posted: Wednesday, July 18, 2018 - 12:10 AM UTC
Going to try something a bit different and slightly ambitious, hopefully it's acceptable for the campaign. Plan to make a Warhammer 40k symbol,
Out of this
Some scrap plywood I had taking up space. Won't be exactly the same but will see what I can do. And if all else fails, I'll resort to a fine molds snow speeder.
Laminated 4 bits of the plywood together, then printed out a cog symbol and glued that on top
Screed some scrap wood to the bottom so I could clamp it in place and raise it up to cut the shape with a jigsaw.
Now to figure out how to make a skull of appropriate size.
Bluestab
Posted: Wednesday, July 18, 2018 - 04:50 AM UTC
I used a 1/20 scale Bandai Brutish Dog for SciFi III. I used it as a 1/35 frame and made a cockpit and added some weaponry. Nice kit and a fun build.
http://modelgeek.kitmaker.net/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=259383&ord=&page=2
I used Pegasus' 1/32 Terminator figures as the basis for their grunts. I'm looking for something about the same size that can fill a heavy assault bot or powersuit role. I was looking at Hasegawa's Gustavs for that role.
Cbacon84
KitMaker: 204 posts
ModelGeek: 60 posts
Posted: Wednesday, July 18, 2018 - 05:31 AM UTC
good idea I think the Gustavs would look really cool for what your doing.
SGTJKJ
#041
KitMaker: 9,855 posts
ModelGeek: 727 posts
Posted: Wednesday, July 18, 2018 - 05:43 AM UTC
Nice to see all the progress, guys!
Iain, unusual choice, but as a mechanicus player myself, I will allow it
Looking forward to see more - a lot of cool projects in this campaign now.
MLD
Vermont, United States
KitMaker: 3,503 posts
ModelGeek: 783 posts
Posted: Wednesday, July 18, 2018 - 06:27 AM UTC
crud!! I did not notice at the time but the newspaper with the date at the top is off screen just at the bottom there as I start on my Tie Striker.
I hope the lack of time stamp will not be an issue.
Mike
SGTJKJ
#041
Posted: Wednesday, July 18, 2018 - 08:40 AM UTC
You’re good, Mike. No problem
MLD
Posted: Thursday, July 19, 2018 - 12:18 AM UTC
Thanks Jesper,
Other than masking the glass, this kit FLIES together. Bandai engineering is top notch.
The inner wing panels are molded in black and are separate from the frames. I went with Tamiya Nato Black for the faded, not full flat black, look.
I'd recommend leaving the lower gun pod and front hull guns off until the very last, they're pretty fragile. The 'wings' are supposedly posable, but the upper right rear top hinge has already cracked from just handling after construction. I'd recommend paint, build wings, touch up, 'weather' and only do final construction right before installation. Then glue the wings into the position you choose.
The rest of the kit is painted with Vallejo air Light Blue Grey, billed as RLM 76, but too dark and too grey for my eye for that use. Perfect here.
Some progress.
MLD
Posted: Thursday, July 19, 2018 - 12:35 AM UTC
Have you seen the Phebus resin kits from France?
The owner passed a couple years back, but the kits are still somewhat available.
Space Legion
Powered armor aliens (I have more poses in storage)
There was a gigantic tank kit and three robots.
Struthio, a recon ostrich walker
A bee looking attack flier and a Dragonfly looking recon flier also in storage.
These might be right up your alley.
Mike
Edit: currently nothing on US ebay
But there are also these, a set of mechanics and a spider scorpion thing I'd not ever seen
MLD
Posted: Thursday, July 19, 2018 - 03:53 AM UTC
Making hay while the sun shines..
Grrr... the wing hinges are EXTREMELY fragile.
I would recommend sanding the pivots BEFORE installation and gluing the wings into place.
And the wingtip frames are not much better
That said, it's a fun little kit and the fastest OOTB build I have done in many a year.
It's a tough kit to photograph, being so long back to front and most of the fuselage under the wings.
Now to go wrestle with the gallery dragon. Wish me luck!
EDIT: am I missing something? There is no folder for the sci fi campaign in the Modelgeek campaigns folder, within the Model Geeks folders, or in the general Campaigns folder on the first page?
Mike
Trisaw
KitMaker: 4,011 posts
ModelGeek: 926 posts
Posted: Thursday, July 19, 2018 - 04:05 AM UTC
Space Legion
Mike
You can still find these occasionally if you look at eBay Europe or Canada (yes, US eBay doesn't show everything).
Casting is very good, but shape is considered OK by today's standards because these figures are many years old.
Alain's sculpting skills improved remarkably over the years before he sadly passed away. He had one or two apprentices for him, but no online shop heir so Phebus Miniatures closed.
I have yet to decide on what to enter.
PasiAhopelto
Uusimaa, Finland
KitMaker: 414 posts
ModelGeek: 33 posts
Posted: Thursday, July 19, 2018 - 06:05 AM UTC
Ready for paint, I think:
Bluestab
Posted: Thursday, July 19, 2018 - 04:22 PM UTC
Mike, Thanks those do look good.
I've been messing around with some of MasterBox's 1/24 figures. I'm sort of putting together a merc team escorting a VIP..I'll call her Princess Yum-Yum for now. My plan is to make a spaceship, cutaway, so you can see inside. In 1/24 scale, it's big and it's a big build so I'm just planning ahead. I'll probably start on those figures I have to get a jump on things.
SGTJKJ
#041
Posted: Thursday, July 19, 2018 - 07:21 PM UTC
Mike
I cannot find it either. I have asked David to make a gallery for us. The issue is the same with the Godzilla campaign and the Stand Bold campaign over on Historicus forum. I hope they will be able to solve it.
SGTJKJ
#041
Posted: Friday, July 20, 2018 - 03:46 AM UTC
The campaign Gallery is now up and running. Please remember to add pictures of your finished models as I will use this to award ribbons at the end of the campaign.
MLD
Posted: Friday, July 20, 2018 - 08:52 AM UTC
Outstanding!
I’ll try to get mine in tonight.
MLD
Posted: Saturday, July 21, 2018 - 08:19 AM UTC
Got my images posted. It took a little poking around, gallery is in the 2018 Campaigns folder on the main Gallery page, not in the Model Geek section.
Thanks
Mike
RedDuster
England - South East, United Kingdom
KitMaker: 6,739 posts
ModelGeek: 20 posts
Posted: Saturday, July 21, 2018 - 10:03 PM UTC
Hi Guys,
Sorry I have bit a bit remiss this getting going on this campaign.
However after my son bought me this guy for Birthday.
I got a bit hooked on Space Wolves, so no purple Space Marines.
But my entry will be a squad of Thunderwolf Cavalry, going somewhere in a hurry... New range of power armour at worlfskin Jack, or a previously unleased CD of Howlin Wolf playing live.
Whatever you do don't get in their way.
Start up.
There are three wolves, with options of Cybernetic repairs and their riders, with loads of ferocious weaponry.
First build a wolf.
Considering the shapes the fit is very good, as are the details, even the paws are separate parts.
The forelegs on, in the case of the left leg I used the cybernetic option.
The head built
And on.
When he is attached to the base he will be leaping.
Painting next.
Si
MLD
Posted: Sunday, July 22, 2018 - 02:31 AM UTC
Looks like a great start Simon. The 40k stuff is lots of fun, damn spendy, but fun.
My son has a bunch a Tyranids and you remind me I've got some Necron 'speeder bikes' in the stash somewhere.. I don't play the game, but do like the design of terminator-esque Necrons, Ancient Space Egyptians, not as much..
I might have to pull them out and get remotivated.
SGTJKJ
#041
Posted: Sunday, July 22, 2018 - 07:49 AM UTC
Welcome onboard, Simon. Interesting choice.
Scipio2010
#401
KitMaker: 310 posts
ModelGeek: 43 posts
Posted: Sunday, July 22, 2018 - 12:04 PM UTC
Greetings everyone.
I love this series of campaigns and Im glad to see yet another installment. Ive enjoyed seeing the initial posts so far and I look forward to everyone's builds.
I was originally going to build a Leopard 2A6 I - an IDF procured and modified Leo. Unfortunately I am currently living out of a hotel for several months on a business trip and limited on my model building.
Therefore Ive decided to build a T29E3 from Takom and depicting it from the Korean War. Basically the Chinese escalate involvement and JS-2 and JS-3's are committed - and the T29E3 is committed to battle for initial combat trials.
The T29E3 is complete, and is next to an M4A2 (76) for scale. I will be using a tri-tonal scheme on the T29E3 to break away from the usual OD.
SGTJKJ
#041
Posted: Sunday, July 22, 2018 - 10:17 PM UTC
Very cool idea, Shawn. Glad to have you as part of the campaign again. Definitivt a large monster of a tank.
Looking forward to see your tri color camo!
