Science Fiction
Discuss any and all forms of sci-fi modeling here.
1:48 AT-ST Endor
hemblecreations
Australia
KitMaker: 155 posts
ModelGeek: 55 posts
Posted: Wednesday, March 27, 2019 - 10:07 AM UTC
Hi All,
1:48 Endor Patrol.
Recipe.
AT-ST & figures- is from Bandai and has been built straight out of the box. The figures are from the Imperial Assualt box set and the troopers are been modified.
Base - is high density foam and cut out and the trees have been done by using aluminium foil and then spakfilla was used to cover the foil and a wide brush was used to make the bark. The branches are from Woodland Scenics, I also used woodland Scenics for the smaller trees.
The ground work is spakfilla mixed with dirt and then spread across the base and once dry I used a mix of static grass, ground up leaves, dirt, railway model foam clumps and blended the lot together and glued to the base. The mud is a mix of spakfilla and paint and it was dapped over the base and once dry I used Woodland Scenics Realistic Water to give it a more wet look.
The undergrowth is from a company called MiniNatur and also Army Painter and once applied to the base it was sprayed with Matt Sealant.
Dixon66
KitMaker: 1,050 posts
ModelGeek: 520 posts
Posted: Wednesday, March 27, 2019 - 10:31 AM UTC
Very cool!
hemblecreations
Australia
KitMaker: 155 posts
ModelGeek: 55 posts
Posted: Thursday, March 28, 2019 - 10:15 AM UTC
Very cool!
Cheers David.
ryally
New South Wales, Australia
KitMaker: 881 posts
ModelGeek: 415 posts
Posted: Thursday, March 28, 2019 - 11:00 AM UTC
Impressive, most impressive!!
Fantastic dio, the way you have done the size of the trees/trunks and that you added the Probe Droid in there as well. The whole seen is very well done, the AT-ST has a great pose and those little Stormies ......... whats not to love about this!!!
hemblecreations
Australia
KitMaker: 155 posts
ModelGeek: 55 posts
Posted: Tuesday, April 16, 2019 - 10:41 PM UTC
Peter -
Thanks heaps Peter I really appreciate the comments and sorry for the late reply.
jimb
KitMaker: 2,274 posts
ModelGeek: 283 posts
Posted: Monday, April 22, 2019 - 06:13 AM UTC
Awesome diorama. Very well done.
Jim
hemblecreations
Australia
KitMaker: 155 posts
ModelGeek: 55 posts
Posted: Monday, April 22, 2019 - 01:06 PM UTC
Jim
Cheers Jim.
Trisaw
KitMaker: 4,007 posts
ModelGeek: 926 posts
Posted: Thursday, April 25, 2019 - 11:43 AM UTC
Excellent! The size, height, and scale of the tree trunks attract the most attention. All the layout and eye candy really makes this diorama special and stand out. It seems simple and yet tells a story too.
hemblecreations
Australia
KitMaker: 155 posts
ModelGeek: 55 posts
Posted: Thursday, April 25, 2019 - 06:33 PM UTC
Hey Peter, thanks heaps mate and glad you like it.
